One of the easiest way to check if NI software is installed is to check the registry - I've attached a VI that will look for NI-Visa, and return an error (in the error cluster) if it's not found.
Like my Answer? Give it a Rating!
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as
is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
