Determining Excel Version using Labview
I have a program that writes data to an excel spreadsheet than run a
macro. The target computer for the application may have excel 97 or
excel 2000. Because of subtle difference between 97 and 2000 I am
required to use different macros and some different VI. I would like
to programmatically determine which version of excel is installed.
This will help me to determine which macro and different VI use.
(3,406 Views)
Have you tried the version property of the Excel_Application object? I only have 97 here so I can't try it out, but it seems like maybe it would work.
Brian
(3,406 Views)
Brian is right. Open an automation refnum, create a property node and one of the properties to be selected is "version".It returns the current version of excel in use(Tried it with 97 and 2000)
Cyril
Cyril Bouton
Active LabVIEW Developper
(3,406 Views)
