Determining VISA COM Port Binding
I can use the attached way for determining VISA COM Port Binding.
simply when I chose port number 3 for example the output will be 3 (number).
How can I reverse the process!
I mean I want to make inter the number and the output to be the port number.
(2,439 Views)
Accepted by topic author BaJa_2020
Hi BaJa,
get a list of all available COM ports, then read the interface number for each of them.
Now you have a list of COM ports vs. interface numbers and can easily reverse the relation…
What is the purpose of your question?
(2,398 Views)
