Determining the pins of NI CB-68LP DAQ
Hi there,
Can we find out which pin is used in the VI I attached?
Kind regards,
Balázs
(2,433 Views)
Look in Measurement and Automation Explorer and see what the task named "Relays" is set up for.
(2,421 Views)
After you locate the Relays Task under Data Neighborhood in Max, you need to right-click the DAQ device under Devices and Interfaces and choose Show Pinout. The pins on the DAQ device should match the CB-68 directly. Your trying to write a U8 to the DAQ device. The Relays task needs to be mapped to an 8-bit port or you'll get an error.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
(2,408 Views)
