Developing an interface system for wind
Hye. I'm currently doing a motorcycle simulator in my university. I'm having a problem to create an interface system for my wind generate from a blower.
So, can somebody suggest what instruments/equipment that i should use in developing the data acquisition system, so that i can generate my data through labview. Prefered the National Instruments product.
thank you.
(2,999 Views)
Your question is much too vague to be able to give any useful advice.
For example, you mention data acquisition but do you actually measure data or generate control signals, or both? What do you need to measure (voltages, currents, how big, how fast?) and how do you control your blower (serial commands, low voltage signal, switching the mains, etc?)
So far, my best suggestion is use some National Instruments DAQ hardware to source and measure the required signals.
(Vague questions get vague answers! 😉 )
(2,979 Views)
