Development of Embedded Hardware
We want to develop electronic equipment that will be used to measure flow of gas or liquid hydro-carbons.
It should be based on 32-bit micro-controller & it must have built-in Floating point math co-processor to allow complex calculations at higher speed.
It should provide or externally support at least following as minimum.
Clock speed above 50 MHz, Four serial ports, Flash RAM or DRAM 8 or 16 MB, 2 MB SRAM, RTC, Ethernet, I/O ports, ADC & DAC, Eight interrupts, etc. The device should be low cost & it has long future availability. It can be completely supported by the development tools.
You are requested to suggest a best micro-controller that can meet the requirements.
If you require any other information, please write to us.
(2,532 Views)
You should have a look at the SB-RIO page, which I think is pretty much what you are looking for.
Shreyas Hebbare
Shreyas Technologies
India
(2,492 Views)
