Deviation and variance and correlation are returning NaN results
I am new to statistics with Labview, and I am trying to modify the statistics example in Labview by reading a column from a csv table and then doing the stats analysis on the data. I tried to make it work, but when I run it, I get NaN results for Standard Deviation, Correlation Kendall, Correlation Spearman, and no result for Covariance.
Can someone please help me fix this VI?
Thanks.
(3,634 Views)
Accepted by topic author Nando88
I just fixed the error. The problem was in the array input.
(3,626 Views)
Hello Nando88 good afternoon,
Thanks for contacting us through the Forum Support, I'm glad that you solve your problem, please let us know if there is anything else we can help you with.
CaEnOs
(3,564 Views)
