Device Net master scanner has error in my project. Error: Plugin not installed?
I am trying to edit a project (application) that I previously wrote. It uses a PXI-1033 chassis and PXI-8532 Device Net scanner. When I open the project, the Device Net Master Scanner has and error sign (yellow triangle with an exclamation point). When I right click on the scanner and select explain error I get this message: The plugin for the selected device is not on your system or the plugin has an expired license. Please contact National Instruments for support. Does anyone know what I might be missing here? I have NI_Industrial Communications for Device Net Installed. That's what I used to create this code originally. What plug in are they talking about???
(2,993 Views)
Hi optional_clause,
Please post this on our Industrial Communications forum. Thanks!
Friar Tuck
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(2,971 Views)
How about no.
Needed to install v14.5. Now fixed
(2,963 Views)
