Device Number and Channel Number?
What exactly are device number and channel number?  I am assuming device number is the number given to the DAQ board (i.e. "1") and that channel number is the number on the screw terminal board where the signal of interest is located.  Is that right?
I've read about it in the help menu but am still confused (I am relatively new to LabVIEW)
(2,689 Views)
Device number is the number given to the DAQ board.  You can use MAX (Measurement and Automation Explorer) to verify the device number.  It will be displayed in the device's property window.  Channel number depends on the device.  If you have a 16 channel Analog Input DAQ, your channel numbers will range from 0 to 15 (or maybe from 1 to 16, depending on the board).  It may NOT be the same as the screw terminal on the connecting block.  The documentation that comes with the board and the terminal block should show which channel goes to which screw terminal.
- tbob
Inventor of the WORM Global
(2,683 Views)
