Device manager: Disable the Secondary IDE channel
Hi all,
How can I enable/disable the Secondary IDE channel (or anything else) in the device manager - via Labview?
I have already tried it via the LV Registry VIs, but I just don´t find it.
Thanks in advance
Mitulatbati
Message 1 of 9
(7,048 Views)
As mentioned in this thread, you can try using devcon, which is a command-line tool that you can call from LabVIEW.
Message 2 of 9
(7,042 Views)
Hi Mitulatbati,
Find the attached content.. It is used to remove any hardware from your compuer.... I hope you'll enjoy lot..
Regards :
Malhar
Greeting from India,
Malhar
Message 3 of 9
(6,770 Views)
Malhar wrote:
Hi Andrew,        Find the attached content.. It is used to remove any hardware from your compuer.... I hope you'll enjoy lot..
As I noted in this thread, please don't password-protect VIs that you post on this forum.The intent is for people to look at code so they can learn how to do things.
Message 4 of 9
(6,754 Views)
Sorry to all. I'v not intentionally kept that VI locked but for some reason its locked previously and that I forgotten. So I here by sent you unlocked VIs, find the attachments and enjoy lot...
Have a great day...
Regards:-
Malhar
Malhar
Message 5 of 9
(6,720 Views)
no attachment...
Message 6 of 9
(6,707 Views)
Malhar
Message 7 of 9
(6,682 Views)
In your file zip not include a "Split String_ogtk.vi" can you help with this.
Thanks.
Regards
Message 8 of 9
(4,936 Views)
It's from the OpenG toolkit.
Message 9 of 9
(4,926 Views)
