Devices and Interfaces not in Max on Production PC
All,
I am trying to diagnose a COM issue and I need your help. First, I am trying to get the Devices and Interfaces node im MAX on the Production PC (which will run the EXE) but I only see Software. I built an installer with the following:
- NI Labview Runtime Engine 2012
 - NI Measurement & Automation Exploter 5.3
 - NI System Configuration Runtime 5.3.0
 - NI-VISA Runtime 5.2
...but I still can't see the Devices and Interfaces node. What else am I missing? I am running Labview 2012.
Appreciate your help,
Eric
(2,949 Views)
DAQmx device driver?
(2,939 Views)
I don't have "Devices and Interfaces" either because I chose not to install both the DAQ and the 488.2 drivers.
(2,936 Views)
It may be worth it to try NI-Serial 3.9: http://joule.ni.com/nidu/cds/view/p/id/3621/lang/en
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,915 Views)
I do not see it within my list of additional installers. Should it be there?
(2,913 Views)
I'll give that a try and respond back.
(2,909 Views)
