Diagram Window gets small everytime I save a Vi.
When I save a Vi, and close the diagram window, when I switch back to diagram (CTRL-E) it appears very small.
Is this some kind of configuration ?
(470 Views)
Thanks, i now found out that LabVIEW has had zoom functionality for a year😀.
If i zoom my diagram window (Ctrl-+), save, closes diagram window, opens diagram window (Ctrl-E) it appeares in the size it was before i closed it.
If i closes the VI and opens it again the diagram wiindow appears in the original size.
I do not know whats your problem, but some questions.
How long have you had this problem?
LabVIEW version?
What happens if you press Ctrl-0
What is your display resolution and screen size?
How do you get your diagram window to be "big" again?
(388 Views)
