Diagram cleanup puts wires behind structure labels
I have a couple of structures which have subdiagram labels visible. When I press "Clean Up Diagram" to, well, clean up the block diagram, I find that some wires and other objects will sometimes clean up to hide behind or in front of the labels. If possible I would not like for this to occur, as I don't want things hiding behind labels. I have attached a screenshot of my Block Diagram Cleanup settings as well as an example screenshot where this issue occurs. Any help on this minor inconvenience would be greatly appreciated. Thank you.
(1,395 Views)
Rule of thumb: If cleanup improves your diagram, it was very (very!) bad to begin with. 😄
A well designed diagram always gets worse with cleanup. Most advanced programmers never have a need for that tool!.
The only time I use it is if I want to look at some horrible code posted in the forum, never ever on my own code. 😄
I recommend to do the same. (Your minor inconvenience is just the tip of the iceberg of all the things I don't like about it.)
(1,379 Views)
The diagram cleanup tool predates the diagram sublabel AFAIK. As such it never learned to avoid them, in fact it doesn’t even know about them.
But I would agree with Altenbach. If this tool substantially improves readability of your diagram, it was pretty horrible. It works to cleanup spaghetti code diagrams to a point where you can get at least an overview of what the code might be meant to do, but when I accidentally apply it to my own code, the result makes me want to scream and I’m very very thankful for the Undo function. 😀
Rolf Kalbermatter  My Blog
(1,329 Views)
