Dialog for browsing DAQmx channels looks different on a PC without LV Development System
Hello!
When I browse for NI cDAQ physical channels from my development PC (Windows 7 64bit, LabVIEW 2013), the following dialog shows up:
This screenshot is the stand-alone executable. And the resulting string is: "cDAQ2Mod1/ai0:2". Perfect.
However, when I run the very same executable on a machine that does not have LabVIEW Development system, but only runtime environment 2013 (automatically included with the installer), the dialog looks like this:
The windows is tiny and not resizable, so it won't let the user see the whole row, there no nice tree structure, and the resulting string is: "cDAQ9181-18B96FEMod1/ai0,cDAQ9181-18B96FEMod1/ai1,cDAQ9181-18B96FEMod1/ai2" which is much less readable than cDAQ9181-18B96FEMod1/ai0:2"
Apart of that, the applications work well.
Is it possible to obtain the 1st dialog box on a PC running only the runtime environment?
Baobob
LabVIEW 2013 SP1
Windows 7 64bit
Windows Server 2012 64 bit
Windows 8.1 32 bit
Message 1 of 8
(3,712 Views)
On the second machinem, is Measurement and Automation Explorer installed?
I don't know why you'd get two completely different dialogs, not just in the items listed, but the overall appearance.  But maybe the dialog is something that is a part of MAX in the first case, and some other module in the second case.
Message 2 of 8
(3,701 Views)
What DAQmx components are installed (and version)
Message 3 of 8
(3,661 Views)
Hi Ravensfan and Jeff, thank you for your answers,
The installer build specification properties for that application is as following:
MAX is not among the recommended installers, and therefore is not present on the lab PCs.
Thanks again
LabVIEW 2013 SP1
Windows 7 64bit
Windows 8.1 32 bit
Message 4 of 8
(3,641 Views)
I have not had the pleasure to use the new auto-select feature yet.  But, it looks like the minimal reqs are identified nicely.  perhaps a slightly bloated installer would serve better in this case.
Install VISA or something and get MAX on board.
Message 5 of 8
(3,629 Views)
Jeff,
Below is the list of installed NI softwares (added MAX and VISA to the installer):
But the weird browse windows is still here.
Do you have in mind another component I could add?
LabVIEW 2013 SP1
Windows 7 64bit
Windows 8.1 32 bit
Message 6 of 8
(3,564 Views)
Accepted by topic author Baobob
DAQmx Configuration support for MAX
Message 7 of 8
(3,556 Views)
It seems that DAQmx Configuration support for MAX was the one. Thank you!
LabVIEW 2013 SP1
Windows 7 64bit
Windows 8.1 32 bit
Message 8 of 8
(3,541 Views)
