Dialog tab control not working after build
Hi
I compiled a vi into an exe and the dialog tab control cease to work.
I tried to fiddle with the build options but had not been able to find out what was the reason.
The tabs are working fine in the vi before compiling.
Anyone have a clue on this?
Goy
(2,735 Views)
I just made a quick demo using a dialog tab control and built it into an executable. It works just fine.
What is your LabVIEW version? Can you attach a simple VI that demonstrates the problem?
(2,726 Views)
Hi Goy,
The issue you described is a known issue in LabVIEW version 6.0, and is fixed in all the versions that follow.  If you are using version 6.0, you may want to consider upgrading.  However, if you are using a more recent version, please let us know so we can further investigate the issue.
Aluma
NI
(2,712 Views)
Hi Guys,
Turns out it was a careless mistake. I made it an indicator instead of a control.
Sorry to trouble you folks.
Goy
(2,687 Views)
