Dialogbox with user input and image...
Is it possible to make a DialogBox with userInput and an image in Labview 2010?
(5,363 Views)
Hi JoVMo,
Do you mean some thing like the attached VIs? Download both VIs , Open main VI and run it and click the button.
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
(5,361 Views)
NITZZ, Instead of the graph, I want user Input. Like a text field that waits for a scanned barcode.
(5,350 Views)
Hi JoVMo,
I thought you will edit atleast that much. Anyway, check this attached VIs. Let me know if you get any doubts.
Nitzz
(5,347 Views)
Ah 🙂 ... The user Input was just my problem.... Your VI is not bad NITZZ... But I still have to bring the cursor in the text field. I want automatic focus on that textfield. No clicking.
(5,343 Views)
Accepted by topic author JoVMo
Right-click string control. Create property node -> Key Focus
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(5,333 Views)
