Dice Frequency
Accepted by topic author David-Baratheon
Very good.
Only tip I have is that you don't need to wire constants into all of those indices on the Index Array function.  They will be 0 through 5 by default when you delete all of those constants.
I would also run block diagram cleanup because there are a lot of wires running backwards and upwards, basically the wrong direction, unnecessarily.  It is easier to read if you keep wires generally going from left to right.
Message 11 of 12
(1,215 Views)
Ok brilliant thank you for all your help, it has been an excellent learning exercise for me.
Hope it benefits anyone else looking to solve this question also.
Message 12 of 12
(1,182 Views)
