Diff. Screen for different cases
Thanks to all for your quite helpful replies..............I will try this and post the experience.....however is there tutorial on "tab control" ??
Message 11 of 16
(1,586 Views)
It's one of the basic LabVIEW controls. Read the help, look through the examples (Help>Find Examples) and take the on-line tutorials.
Message 12 of 16
(1,578 Views)
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
Message 13 of 16
(1,560 Views)
MSD100 wrote:
Thanks for reply...I will try the example...To add more I was thinking that....is this possible to divide single screen into 3 or 4 parts(or blocks) and having enable button for each part..so when user select that button that part change color(look active) and all other becomes gray or unusable(look inactive....)
is it possible??
You should check the following VI (which is not mine but I do not remember on which thread I found it... sry for the author). The active Tab will change color.
Message 14 of 16
(1,552 Views)
is it possible??
THat can be achieved using four tab controls with a single page each and the tab hidden. Simple use the disable property to enable or disable each.
Ben
Message 15 of 16
(1,547 Views)
You can also load the VI your are calling in a subpanel. Make the VI front panel the same size as the subpanel of the main VI.
Ben
Message 16 of 16
(1,538 Views)
