Difference between BridgeVIEW and LabVIEW DSC
- No -
(6,695 Views)
6.1 - 2.11 = 3.99
I hope this helps,
Ben
(6,695 Views)
BridgeVIEW and LabVIEW DSC (LVDSC) are essentially the same thing. The difference is in the package. BridgeVIEW was a stand-alone package which you could install and use independently of LabVIEW. Was a completely different piece of software.
However, LVDSC is built on top of LabVIEw as an add-on module. You'll need LabVIEW to install and use LVDSC.
BridgeVIEW was turned into LVDSC after the release of its v2.1.1. And the current version of LVDSC is 6.1.
Hope this helps,
Khalid 🙂
(6,695 Views)
LabVIEW DSC is the new version of BridgeVIEW.
BridgeVIEW would correspond to the LabVIEW 5 Version.
LabVIEW DSC came out with LabVIEW 6.0.
The latest version of LabVIEW DSC is 6.1 which came out about a month ago with LabVIEW 6.1
(6,695 Views)
