Difference between LV PDA module and touch-panel module
What is the difference between LabView's PDA module and touch-panel module? I want to recompile my application developed on a Win XP environment for a touch-screen single board computer running Win CE. From what I have read, it seems like both PDA module and the touch-panel module would be able to do the task - but what is the difference between the two modules?
(3,900 Views)
sstolteq:
The LabVIEW PDA Module allows you to create applications that run on Microsoft Windows Mobile for Pocket PC devices. It is also compatible with several NI data acquisitions devices, including the USB-6008, USB-6009, CF-6004, DAQCard-6062E, DAQCard-6024E, and the DAQCard-6036E.
The LabVIEW Touch Panel Module, on the other side, allows you to create human-machine interface (HMI) applications to communicate with NI embedded real-time platforms such as Compact FieldPoint, CompactRIO, and Compact Vision System. It is optimized for developing HMIs to Windows CE touch panel devices such as the NI TPC-2006.
I hope this helps and please let me know if I can help further.
Rudi N.
(3,865 Views)
