Difference between PDA Module and Touch Panel Module
Does anyone know the difference between labview pda module and labview touch panel module?
Ali
(3,969 Views)
ali,
LabVIEW PDA Module is meant for building applications that run in the smaller memory space common to PDA devices running mindows mobile, while the Touch Panel Module is made for touch panels that can run different versions of touch panel Windows.
Peter
Peter C.
(3,950 Views)
Is there more details about the differences somewhere?
(3,923 Views)
Raybot,
Are there specific things you have questions about? I dont think we have a full document about the differences, because theyre for pretty different target types. That said, if you have a question about a specific feature difference, we should be able to figure that out for you.
Kyle M.
Applications Engineering
(3,901 Views)
I'm most interested in:
1.   A way to print to an off the shelf printer.
(3,883 Views)
That is most likely only going to work if at all, on the Windows XP Embedded variant of Touch Panel Module. But this module being based on ARM CPUs it is very questionable you will find a printer that has a driver that can be installed on that target.
Rolf Kalbermatter  My Blog
(3,870 Views)
