Difference between filters
I have a simple vi that reads analog signals, which have to be filtered. In Labview (I'm using version 7.0, not that it matters), there are a many different types of low-pass filters (Chebyshev, Butterworth, etc.) and limited to my knowledge right now, they all seem to be somewhat similar. I tried to find their differences and the pros and cons of each filters but to my dissapointment, i couldnt. Can somebody pls let me know what are the pros and cons of the filters, or at least direct me to a webpage that contains this information? Thanks, it is highly appreciated!
(5,639 Views)
Lan wrote in news:50650000000800000060A30000-1042324653000
@exchange.ni.com:
> Hi,
Butterworth filters are maximally flat in the pass band, and roll off more
slowly in the reject region. Use this filter if constant gain in your
passband is a must.
Chebychev filters fall like a hot rock in the reject region, at the expense
of ripple in the pass band. Use this if you need a rapid descent into the
reject region.
Bessel filters are linear phase, equivalent to a simple time delay, thus
you have a time delay in the output, but no phase distortion. Use this
filter if you cannot tolerate phase distortion.
If you need more description on other types, just list the names, and I'll
try to help.
Also, in general, its useful for further analysis if you pass ALL your
channels through the same filters
Scott
(5,639 Views)
Bessel: minimum phase perturbation
Butterwotrh: maximally flat passband
chevy: steep cut-off
Sometimes, you want to have these in hardware to keep your system from
undersampling the signal.
Lan wrote:
> Hi,
> Th
(5,639 Views)
Also check chapter 4 (about Digital Filtering) in the LabVIEW Analysis Concept (pdf) document. You can access it from the Concepts and Techniques section when you open the LabVIEW bookshelf (Start>Programs>Nat. Inst.>LabVIEW 7.0>Search the LabVIEW Bookshelf)
(5,639 Views)
Hi Lan:
Probably the most comprehensive and understandable treatment of filters is to be found in the ARRL Radio Amateur's Handbook, just about any edition since the 1970s.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(5,639 Views)
