Difference between model Number and serial number.?
I have 2 instruments
Instrument 1 is 2 parameter display
Instrument 2 is 3 parameter display
Now how can know what is serial no. and model no. corresponding to the above instruments.
Message 1 of 8
(8,811 Views)
What instruments?
What type of instruments?
What does the manual for the instrument say about reading the serial no.
How are you communicating with them? Are they GPIB instruments? Are they DAQ instruments?
What do you mean by "2 parameter display" and "3 parameter display"?
Omar
Message 2 of 8
(8,808 Views)
Data logging of temperature and humidity and pressure through modbus protocol
Message 3 of 8
(8,803 Views)
Developing universal data logger with help of labview
Message 4 of 8
(8,801 Views)
That tells us absolutely nothing. You have to look at the manuals for the instruments and see if they provide a means to get that information. We are not mind readers. We do not know what instruments you are using. If you cannot understand the manuals, then post a link to where they can be found and perhaps someone may be willing to tell you the command.
Message 5 of 8
(8,794 Views)
Ok thank u sir
Message 6 of 8
(8,790 Views)
Accepted by topic author Nagaa
I am not familiar with modbus.
But, I think that is dependent on the manufacture of your temperature, humidity and pressure devices
What does the manual from the manufacture of your devices say?
Is there a command that your devices will reply to?
Omar
Message 7 of 8
(8,788 Views)
yes it sends reply also . ok sir i will find out clearly by looking into manual .
Message 8 of 8
(8,780 Views)
