Difference between running continuously and While loop
I guess the it all comes down to:
The "Run Continuously" button is an IDE feature and shouldn't be used as an actual coding strategy.  Same as the "Pause" and "Highlight Execution" buttons.  (And the breakpoint.)
Bill
CLD
(Mid-Level minion.)
Message 11 of 20
(3,103 Views)
It's just a personal preference. Maybe C prople are more verbose on this.
Message 12 of 20
(2,970 Views)
It's NOT a personal preference.  There are real differences between the two.  Please read the whole topic.
Bill
CLD
(Mid-Level minion.)
Message 13 of 20
(2,954 Views)
Message 14 of 20
(2,950 Views)
@billko  ha escrito:
This forum is a bit tricky: Every comment goes as an answer to the original question. I was talking about the 0x hex thing. Take it easy 🙂
Message 15 of 20
(2,946 Views)
@kuashio wrote:
@billko  ha escrito:
LOL 😄
Bill
CLD
(Mid-Level minion.)
Message 16 of 20
(2,927 Views)
No.  Every answer just goes to the end of the thread.  There is no direct connection to the first or any later reply.  If you aren't replying to the previous message where it is obvious in the flow of the thread what you are talking about, then use the quote button to add the text from the message you are replying to.  Edit the quote if necessary to eliminate parts of the message are irrelevant.
Message 17 of 20
(2,922 Views)
Sure. Thanks, you rock.
Message 18 of 20
(2,893 Views)
So, I'll add some more.
Let's start with this exercise:
  • Create a new blank vi.
  • Create two numeric controls X and Y and a STOP Button
  • Create numeric indicator X+Y
  • On the block Diagram drop an ADD primitive and wire it up the obvious way
  • Let's also insert a Slall Dataflow.vim on any wire and create a 500msec constant (no need to burn a CPU core here)
  • Now the tricky part... CTRL+I to launch the VI Properties Dialog Execution page CHECK the box  "Clear Indicators when called" and press Apply
I just heard a whole lot of eyelids snapping open!  Watch the indicator while you run continuously and adjust X and Y.  The math looks a bit off doesn't it?
Go ahead and drop the while loop and wire up the STOP button.
Run the vi.  Hallelujah 2+2=4 again!
Message 19 of 20
(2,885 Views)
That should have demonstrated that there is a lot more involved in call setup than you expected in a safe but, observable situation.   The involkng of the clear indicators method, if enabled, is only 1 of many differences between run continuously and running a loop.
Message 20 of 20
(2,881 Views)
