Difference between the Matlab and LabVIEW Hann (Hanning) functions
Hi All,
I'm hoping someone out there can satisfy my curiosity. I have been porting over some code from Matlab to LabVIEW and came accross a difference in the two implementations of the Hann function. Essentially:
LabVIEW has array length = n
http://zone.ni.com/reference/en-XX/help/371361J-01/lvanls/hanning_window/
Matlab has array length -1 = N.
http://www.mathworks.co.uk/help/signal/ref/hann.html
(where n= N in the two implementations)
As I'm not very clued up on signal processing I was hoping someone could explain why there is a difference in implementation and why array length was chosen for the LabVIEW implementation. According to wolfram the parameter a is full width at half maximum:
http://mathworld.wolfram.com/HanningFunction.html
http://mathworld.wolfram.com/FullWidthatHalfMaximum.html
Is the difference just due to the interpretation of what this value should be?
I've attached a modified version of the window comparison example to illustrate the diference.
(4,258 Views)
Could part o the confusion be due to the fact that LabVIEW arrays start with index zero and matlab arrays start with index one?
I'll look at your code later...
(4,252 Views)
It did cross my mind but I validated the LabVIEW code for the Matlab Hann, alsoo it states in the Matlab documentation the window is over 0<= n 0<= N, so I don't think it's an indexing difference unless I'm missing something
(4,245 Views)
