Different data types in waveform graph
I'm displaying third Octave data from the 1/3 octave VI into a octave graph. After I'm done with my analysis, I would also like to display narrowband data in the same graph with a control to allow this. I'm displaying multiple channels. Any ideas?
(2,959 Views)
Hello �
Where is your narrowband data coming from? Is it also a cluster of two elements or is it a different data type?
S Vences
(2,959 Views)
Hello thanks for responding,
I'm plotting data on a octave graph from the 1/n fractional octave vi (data type is a cluster of 3 elements). The narrowband data is also a cluster of 3 elements.
(2,959 Views)
Hello �
The octave spectrum coming from the 1/3 octave analysis vi is a cluster of 2 elements.
Normally you would use a build array function to create a multiplot graph. However, all the plots going into the build array function have to have the same data type. A cluster of 2 elements and a cluster of 3 elements is not the same data type.
You need to express your narrowband data in a 2 element cluster to be able to plot it in the same octave graph.
Hope this helps.
S Vences
(2,959 Views)
