Different elements in two 1 D array
Helloo
I am having two 1 D arrayes. one array consists of r values and other theta values. For example (See attachement) , I want to take the two r values for same theta values and so on fro other tetha valules. how is this possible?
Nghtcwrlr
Message 1 of 31
(5,630 Views)
Accepted by topic author Nghtcrwlr
You did not tell us what kid of output you want, but a FOR loop should do what you need. Autoindex on the "angles" and not on the "Rs", and you'll get a 2D array.
Message Edited by altenbach on 12-15-2008 04:13 PM
Message 2 of 31
(5,613 Views)
hello,
thing like that ?
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
Message 3 of 31
(5,611 Views)
sorry for collision Master A
Message 4 of 31
(5,609 Views)
No problem. As you can see, you have twice as many FOR loops as you actually need, but the idea is the same. 😄
Message 5 of 31
(5,605 Views)
Hello Tinnitus
Am having Labview version 8.2.. I coudnt open ur VI. But still I used the vi that was posted by altenbach.
anywy thnx for ur help. Is there actually a way to open the higher versions of VI in lower one?
Thnx
Nghtcwrlr
Message 6 of 31
(5,581 Views)
hello Altenbach
Thnx for your help. I was not aware of the indexing stuff.. now it wrks. but still there is some difference in final answer...
for example suppose there is only 1 value of r ; r = 3. and theta = 90,180,270,360
SO complex numbers should be when  r=3 and theta =90 (1.5708 rad) ----->0+3i . the Re part of the answers is different in two cases.  See attachmenet
I think since it is anyway zero, that difference doesnt affect, right? What could be the reason for that difference in results?
Nghtcwrlr
Message 7 of 31
(5,578 Views)
Its not possible. If you want to do so, just post here. Somebody using that higher version will convert it for your version. Smiley Happy
Message 8 of 31
(5,576 Views)
done, i delete the unneeded loop
Tinnitus
Message 9 of 31
(5,569 Views)
it's normal because of approximation of pi and calculation, try to use multiple of pi=3.14xxxxxxxxxxxxxxxxxxx  given in numeric palette -> pi constant
also you can modify numeric displaying  just for eyes to round values ...  (ex 3 digit after coma)
it doesn't affect standard calculation , expect in critical "asservissement" i think (translation not found)
Tinnitus
Message 10 of 31
(5,539 Views)
