Different sampling rate
Hi to everyone!
I'm quite new with Labview NXG and any suggestion would help. I'd like to acquire different analog signals at different sampling rate (cDAQ 9189 with NI 9205), is that possible? I was told it could be done by grouping the channels.
Attached the .gvi
Guglielmo
(2,350 Views)
Hi uil,
the NI9205 provides only one ADC with a multiplexer circuit to read (upto) 32 channels: this only allows for one sample rate for all channels.
You can use a higher samplerate and decimate the data to your desired data rates!
(Btw. you should mark your thread as "NXG" as requested in the header of the LabVIEW board! Also attaching such down-scaled images is pretty senseless.)
(2,339 Views)
