Differential pressure sensor? range: 0-3500 Pa - rate: 10 ms - sensitivity 1 Pa
Hi
i need a pressure sensor which can measure differential gas pressure in the range 0-3500 Pa at a rate of 10 ms and sensitivity of 1 Pa or lower. The sensor has to be connected with a tubing ~2 mm inner diameter.
Preferentially connected via a NI-USB
Thanks in advance, Gernot
(3,135 Views)
Hi Geab,
If you are searching for hardware, you can take a look at:
https://www.ni.com/en-us/shop/category/strain-pressure-and-force.html
You can here find hardware to connect your sensor, among others USB devices.
(3,095 Views)
Thanks Kristoffer
if you could assist in finding the right Honeywell sensor or something similiar to the intersema Sensor http://www.intersema.ch/index.php?option=com_rubberdoc&view=doc&id=86&format=raw
or
http://www.intersema.ch/index.php?option=com_rubberdoc&view=doc&id=40&format=raw
(which I am currently using via Oak Toradex with Labview 2010 Full developer)  that supporst my application I would be happy.
Would it be possibleto use a low cost NI USB DAQ to acquire data at 10 ms?
Cheers, Gernot
(3,069 Views)
Hi Geab,
For this issue you must contact your local NI branch by phone, and they'll be able to instruct you in what to do.
(3,064 Views)
