Difficulty reading data from arduino board.
I am using labview to communicate with arduino. When I am using serial monitor in arduino IDE and hyperterminal then its communicating but when I am using labview then Its not communicating. I am sure that there is no problem with VI
I am not able to read any data sent from arduino board.
My config is as below,
Baud rate = 19200;
databits = 8;
stop bits = 1
parity = None
flow control = None..
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,782 Views)
@Ranjeet_Singh wrote:
When I am using serial monitor in arduino IDE and hyperterminal then its communicating but when I am using labview LabVIEW then Its not communicating. I am sure that there is no problem with VI.
Then it should communicate with the board, shouldn't it...?? Smiley Surprised
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,779 Views)
Yes it should..
Later I found if I write something to arduino then I am not able to read data sent from arduino.. I wrote one program which is only sending data then I am able to read through labview but when I am writing some value to arduino then I am not able to read the data sent by arduino..
Smiley SurprisedSmiley SurprisedSmiley SurprisedSmiley SurprisedSmiley Surprised
--Ranjeet
(2,774 Views)
