Difficulty to deploy a program on the RT target
I have a problem when I want to deploy the RT target (see attached jpg) of my CompactRIO. It's only with this project that it's happen. I compiled the FPGA VI ... everything is fine. After, I run the RT VI ... everything seems ok but after 2 sec, the RT disconnect. I don't know where is the problem, does somebody can help me!
Thank you
(2,718 Views)
Based on your information this is the only project that you get this behavior, so in the project for your real-time target do you have the IP address configured? If so, did you choose connect?
Also, since you say it is only on this project, if the above does not help what if you created a new project with the same VI's what behavior do you get? If that does not change anything then either it is something within your VI's or something in the setup of this project compared to the other projects.
David A.
(2,686 Views)
