Digicam (Live Stream)
Hi @ all,
is there a way in LabView (2010 or2011), to get a live stream (image) from thehelmetcamera like "Gopro HD Hero (http://de.gopro.com/hd-hero-cameras/)" or "Rollei ActionCam 100  (http://www.rcp-technik.com/typo3/index.php?id=703&no_cache=1&tx_ewcamerasheet_pi1%5Bview%5D=detail&t...)".
It maybe a differentcamera,butthe camera shouldhaveat leasta resolution of min. 720p.
THX Schnegg
(4,621 Views)
Can't speak for the GoPro, but the newer Contour cameras (I have the older 1080 version) can stream over bluetooth to android/ios devices as a "preview".  I believe this uses their own protocol, you'd have to spend some time deciphering that stream to get a useable image out of it.  ContourConnect also allows you to modify settings (exposure, contrast, mic gain, resolution/framerate).
Haven't heard of anyone taking that stream to anything other than an android/ios device using contour's provided software... not saying it's not possible though.
Would you be streaming to a PC?
(4,616 Views)
Thanks!
Yes i would stream it to a PC which is in an roboter and the cam is on the top of it.
Connection to the PC with Ethernet.
(4,610 Views)
If you want to stream the video over ethernet, a contour/gopro is the wrong camera for the job.  A cheap network camera will do the trick there; you can find those for about $20 shipped from china on ebay.
If you really wanna go crazy with it ($$$), pick up an NI Smart Camera... dual GigE on-board.
(4,605 Views)
Thanks.
No. We only stream the LabView Programm (VNC). But also for this application the GoPro is exaggerated.
That's right, and I think a HD Webcam could be enough for this application.
(4,601 Views)
