Digital Error
i have a simple vi set up to reset my DAQ board (an AT-DIO-32F),
and then configure a group containing port 0 for input, and then configure
it to run in handshaking mode. I then configure a buffer to take a
certain number of scans and use a buffer control vi to start the
acquisition. WHen I try to run it, everything functions until I try to
use the start command on the buffer. It gives me error -10008, with the
possible reason that the specified group is invalid. I have no idea
what's going on. If anyone could offer enough help to get this started, I
can probably do it from there.
The setup is an AT-DIO-32F and a PC-TIO-10 running in a Gateway
Pentium 120. The PC-TIO-10 is reset at the beginning of the vi, but not
accessed after that. I
t's LabView V. 5.0.1.
Josh
[See first answer for additional information]
(3,692 Views)
[Attachment(s) for question]
(3,692 Views)
