Digital I/O: how to drive a device and read input at the same time?
I'm a Labview newbie, trying to use Labview 2012 and an MCC USB-1208FS-Plus DAQ box to spin a stepper motor and read data from the digital optoswitch on the motor, which gives a pulse once per revolution. My VI is attached. I can drive the wheel okay via the ULx library by sending a sequence of 1,0 signals in a While loop to bit 0. I added a nested inner While loop to try and read the digital optoswitch (via bit 1) in series after sending each pair of signals but I got this behaviour:
it moves the the wheel 1 step, then happily samples the input from the switch as many times as I tell it to, but then when it goes back to the outer loop to drive another step it gives "Error 42 at ULx write. Possible reason: Digital Port not configured correctly for requested operation". Since I can address the drive and the optoswitch with no trouble I am puzzled about why it fails when I try to do both in sequence. I hope this is an obvious one to those who understand Labview...
Grateful for any help at this stage....
Phil
(2,951 Views)
The forum you posted into is for messages about the operation of the forum.
You need to post in the LabVIEW forum.
I've sent a message to the moderator to have the message moved there.
(2,936 Views)
Thanks.
(2,916 Views)
