Digital Input VI
Hi, I'm using a DAQ 6025E card for data acquisition. I need read
1 16bit port from a data Encode, so that I use DIO0 and PA ports
on the card. I use Digital_2_port.vi to read check my configuration,
however, there is always a error code 10007 appeared. I have no
idea what's wrong in my configuration. Since I can read port 0 ok,
but not port 1. Any suggestion?
(2,957 Views)
This example will work if you read the VI Information and address the
ports correctly. For the 6025E, the port numbering is 0, 2, 3, & 4.
Also, in case you're not aware, there is a user group dedicated to data
acquisition specific questions in any programming language at
natinst.public.daq.general.
Erin Bray
> Thanks,
(2,957 Views)
