Digital Output Question
Im very inexerienced with LABVIEW. I am trying to set up some digital output channels that turns on a vacuum pump when the connected vacuum falls below a certain value (probably set with a dial). I think the simplest way at this point is via the DAQ assistant. It will be greatly appreciated if someone could recommend examples that are related to this or explain to me how I would go about setting up a VI for this. Thanks.
-meter
(2,817 Views)
How does your PC interface with the vaccum pump?  Are you using a DAQ card?
Once you determine that, you can do a search on that topic within this forum.
(2,799 Views)
