Digital Waveform Graph - active plot height and position
Hi!
Is it possible to arbitrary control the Height (in pixel) of a single plot of a DWG (Digital Waveform Graph)?
It seems I'm not able to find the correct property node to use.
In addition, is it possible to control the Y position (I mean in pixel) of every single plot so that for example it follows the position of the corresponding legend entry?
Thanks and Best Regards
Dario
(3,553 Views)
I don't believe you're able to alter the height/length of a single plot of a Digital Waveform Graph. Below is a link that may help you in customizing your plot.
Customizing a Plot on a Digital Waveform Graph Using the Plot Legend:
https://www.ni.com/docs/en-US/bundle/labview/page/customizing-a-plot-on-a-digital-waveform-graph-usi...
Hope this helps!
-Kale
(3,502 Views)
Hi!
Thanks for the reply!
Eventaully I went for an analog waveform graph, which 'let' me customize offset and amplitude of every plot at will..
The only drawback is that apparently there is no way to use a tree legend for analog plots...
I really liked the tree view legend of digital waveform graphs...
I'm planning to code my own tree legend somehow..
(3,494 Views)
