Digital Waveform Graph problem ( spread data in multi lines instead of one line)
Hi , I have used a digital waveform to show series of 1 and 0s but -As can be seen in the attached picture- instead of showing them in one line , the waveform spread it into multi lines. Could you please help me to configue the digital waveform grapg so I can see data in series not multi lines
(3,074 Views)
Where is digital waveform data...??
can you save the data, which you're trying to display in a graph, as a constant & share here?
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,059 Views)
Thanks Moderator1983. I made a mistake, the problem is fixed now. I just had to add a transpose 1D array
(3,043 Views)
