Digital Waveform cannot show all plot in the graph indicator
Dear all,
Currently i am facing a problem where my digital waveform cannot show all plots in the graph. I had configured total 31 line for the graph but it only show 29 line eventhough there are some empty space at bottom. May i know is there any maximum line to plot a digital waveform graph? The plot is start from line 3 to line 31. I had tried to enlarge the graph area but it still the same. Here i attached my vi for your reference.
(3,598 Views)
Hi Loop,
why did you switch off the Y scale autoscaling?
Enable it…
(3,570 Views)
Hi GerdW,
Thank you for your reply.  I already enabled the y-scale auto scaling and re-run the program. But it still the same.... You can make all lines appeared after enable auto-scaling?
(3,560 Views)
Hi GerdW,
I made the property autoscale in program then only it works. Thank you for your help 🙂
(3,557 Views)
Hi Mind,
for me it was sufficient to set the Autoscale in the context menu of the graph.
No idea why you would need an additional property node…
(3,550 Views)
I had been reading this thread from the beginning.  After I saw your message about turning on autoscale, it felt like it didn't help me either.  But then after your further messages, I tried it and it did work.
I have no idea the difference between the original and attempt and later.  Something is erratic about that graph.  Latest check, turning on autoscale seemed to make it work, and I did not need to add a property node.
(3,545 Views)
