Digital data plotting with time
If anybody worked around situation, needs idea sharing
Available Info :  8 Channel digital data is available with time stamp.
Requirement : User should able to select "n" no. of digital plots based on selection, Also user should able to mesure time between 2 cursor on graph.
Thanks in advance.
(2,818 Views)
Thank you for contacting National Instruments!  I believe that the solution that you are looking for can be achieved using a Digital Waveform Graph.  This can be found within the Controls Palette » Modern » Graph » Digital Waveform Graph.  From here you can input an array of Digital Waveforms to display on the front panel with the X-Axis scaled by time.  Using property nodes you should be able to select the number of plots that are visible on the graph and perform functions involving cursors.  I would specifically look at the Active Plot property and Plot » Visible in order to select the visible plots.  Then I would look at the Cursor » Index in order to compare two of them and find the time between them.  I hope this helps!  If you have any further questions please just post them here!
Thanks!
Bob H
(2,794 Views)
