Digital filter design Toolkit error(bug) - When build DFD FPAG Code.
Dear all,
When I used the DFD toolkit to create the FPGA code automatically, I got the error message " No valid FPGA target is installed".
(You can find the attached picture.)
I have already installed the related software and driver.
(LabVIEW 2020sp1; CompactRIO 20.5; LabVIEW 2020 toolkit (RT, FPGA, DFD)
It seems like a bug.
When I used the LabVIEW 2017, everything is very well. maybe some FPGA target is out of service in labview2020   Capture.JPG
Message 1 of 8
(2,961 Views)
Do you mind letting me know which LabVIEW version you're using, the 32 bit or the 64 bit one?
I'm asking because the 64 bit version doesn't support a Real Time Module, as stated in the following KB.
What Software Do I Need to Program My cRIO? - NI
Let me know, so we can see what the next step could be.
Cheers
Message 2 of 8
(2,917 Views)
thanks your reply.
I am using labview 2020sp1 32bit.
And I have reinstalled the toolkits and driver. The error is still there.
B.R
Message 3 of 8
(2,911 Views)
Great.
Are the toolkits and drivers all the 32 bit versions?
Also, in LabVIEW 2020, sometimes this issue could occur because the DFD toolkit was installed before the FPGA and RT modules. Can you please confirm that you installed the RT and FPGA modules before the DFD toolkit?
One more thing: could you please let me know what cRIO you are using?
Message 4 of 8
(2,907 Views)
I am using crio-9041.
Some information:
1, when I using IP generation in a project, I can get the FPGA code automatically. Maybe it means the driver and software version is not a problem. But when I try to use the VI (in the toolkit)to generate the FPGA code,I got the error.
2. When using the labview 2017, it will create a project with crio-9081 default. If I copy the project to labview 2020, it will show a waring triangle. But the vi and fifo can works very well.
thanks.
Message 5 of 8
(2,901 Views)
Good. Thanks for giving me all this info. I'm gonna try to replicate your issue on my side and see where the problem is coming from.
I'll get back to you soon.
Message 6 of 8
(2,897 Views)
   Do you have any update? Thanks
Message 7 of 8
(2,756 Views)
I meet the same problem, i dont konw how to solve it neither.
Message 8 of 8
(2,213 Views)
