Digital output on a pci-6601
I have just received a pci-6601 card from NI. I would like to use the digital outputs from LabVIEW but when I try to use the supplied vi's, I get an error message that the port width is incorrect or not supported. Am I using the right vi's, and if not, where can I get them? The card works fine through the NIMAX test panel.
(3,381 Views)
The NI 6601 and NI 6602 only allow one 32-bit port configuration. Try changing the default port configuration from 8/16 to 32-bits.
(3,381 Views)
Thanks, this suggestion works fine.
(3,381 Views)
