Digital output vi to control pneumatic valves
I'm trying to create a vi that will control the state of 16 relays via the 1324 module.
Each relay must be enabled and disabled at specified points in time (all different) from an absolute starting point.
This may be a novice level question but I'm afraid that's all i am.
Mark....
(3,536 Views)
Yes this is something doable fairly easily. Infact NIDAQ 6.9.0 now has examples (for labview) that lets you do that.
You will pick this up quickly.
A Rafiq
(3,536 Views)
Can someone send me a copy of the 6.9.0 example that A Rafiq is reffering to? I'm currently using LB6.0i.
(3,536 Views)
(3,536 Views)
If you have NIDAQ and labview installed, you already have the examples. In labview go to HELP>EXAMPLES>IO INTERFACES>DAQ>SCXI>SCXI 1160
A Rafiq
(3,536 Views)
Sorry about that i've actually seen that VI. My problem is digital output signals with timers
(3,536 Views)
