Digital trigger, analog output from file
I'm trying to produce analog output from text file. I attached text file with inputs and vi file. When I connect oscilloscope, there is no waveform.  I'm using labview for two days. What's wrong with my code ?
Message Edited by _thomas on 03-05-2009 09:44 AM
(3,144 Views)
_thomas,
Thank you for posting on the NI Forums. I was able to open your code and look at it, and I don't see anything wrong with it right away. Is the program giving you an error or are you getting the wrong data output to the line? Are you seeing any data on the line at all?
Aaron W.
(3,110 Views)
Accepted by topic author _thomas
Everything is OK now, I had a problem with Onboard Clock.
(3,101 Views)
