Digital unit control to string conversion
Hi Everyone,
I'm trying to convert a digital control with min as unit, to a string.
The matter is that it will convert it to seconds before it updates the string indicator.
I noticed that the "format into string" will always convert first to the base unit (unit multiple value to unit value conversion), just like kW to W (10 kW will output 10000 W) for watt unit.
Is there a way to format the input value without this conversion to the base unit first ?
Thanks to you...
(3,188 Views)
Accepted by topic author LMartin
If you look up the Format Specifier Syntax in the LabVIEW help, you will see a Unit option.
Here is the format you want to keep the string in minutes: %{min}g
(3,172 Views)
Thanks crossrulz,
Didn't know about this one...
Cheers
(3,152 Views)
