DigitalPersona fingerprint scanner driver
Greetings,
I recently purchased a DigitalPersona U.are.U 4500 fingerprint scanner and would like to integrate it into labview for various purposes. Using the free SDK that DP provides I was able to quickly create some test code (attached here) but thus far I am unable to get it to work. Specifically I am using their ActiveX external code but I am not necessarily tied into that as they also provide .NET and few others in their SDK for interop.
Can anyone shed some light on what I am doing wrong? I am guessing it has something to do with the event handler.
Just some background:
Fingerprint scanner
SDK download
Any help is greatly appreciated.
(6,384 Views)
Hi Nooxious,
i can't see any mistake in the part you've attached. What are you doing in the callback vi? That's the function which will be called. There you have to place the code to react on the event.
Mike
(6,365 Views)
Have you had any luck communicating with the DigitalPersona U.are.U 4500 fingerprint scanner? I'm interested in purchasing one myself, but only if I can use it with LabVIEW.
Many thanks,
-Matt
(6,238 Views)
You could do this with LabVIEW with USB Instrument control, using VISA commands. I have a link to an article that describes how to do this but as the article states, you will need to understand the device's communication protocol.
USB Instrument Control Tutorial
http://zone.ni.com/devzone/cda/tut/p/id/4478#toc1
Patricia B.
(6,174 Views)
