Direct Read and Write to an Access Database
Is it possible to write directly to an Microsoft Access Database or setup an ODBC database programatically?  I am trying to eliminate the need to manually setup a ODBC database for my application.  I am using LabVIEW 7.1 and SQL toolkit is installed.  Any help is appreciated
(2,886 Views)
You can create a udl file and copy the connection string. There is an example called 'Using Connection Strings' (at least in modern versions of the toolkit).
(2,877 Views)
