Direct port access vi
Hi all,
Is there a vi or dll, which enables transfer of big amount of data via Ports?
My intention is to receive a lot of data via ATAPI interface. It is no problem to use the vis in the \vi.lib\portaccess.dll, but they read single U8/U16/U32. If I use these vi´s (basically dll´s) in a for loop in LabVIEW, it is not fast enough. I need a dll, which has big array output with the data, and recieves the data fast from the ATAPI device. There is a possibility by the TVicHW32 (you can take a look on http://www.entechtaiwan.com/dev/hw32/index.shtm). But I don´t want to install this, because I need license... Using the TVicHW32.dll without installing, so only copying doesn´t work.
I hope you have the answer
regards
Mitulatbati
(5,391 Views)
Did you tried to use the IN and OUT-port VI's standard in LV
(5,345 Views)
Hi
As I wrote, it´s not fast enough to use them in a loop 😞
(5,342 Views)
With other software solutions on a PC running under Windows (I assume) it will not be faster then in LV.
Only when you write it in assembly it will be faster, but still with the windows overhead.
I think you have you solve this in hardware or an other OS (LV-RT or assembly in MsDos)
Why does it have to be so fast ?
(5,339 Views)
Hi
It has to be fast, because I write "Data Transfer Rate" tests, and I have to read a lot of data and measure the transfer time. With a slow transfer rate I can´t measure anything reliable. There is a routine in TVicHW32.dll, and it works perfect.
regards
(5,333 Views)
@mitulatbati wrote:
Hi all,
regards
Mitulatbati
Take a look at the OpenG portIO library. It may or may not be much faster but there is the source on sourceforge for the device driver and the user space DLL and with a Microsoft DDK, Visual C and some time you can extend it in any way you want (but you will need to know some good C or take time to learn it).
In fact you shouldn't need to change anything on the C side, a new VI reading an array of bytes instead of just a single skalar should already work. There might be however one more problem. When you say you want to talk to an ATAPI interface are you sure you talk to it over port IO and not some mapped memory adress. The OpenG port IO library won't work for mapped memory addresses as that requires lots of interaction with Plug&Play.
Rolf Kalbermatter
Message Edited by rolfk on 11-01-2007 10:49 AM
Rolf Kalbermatter  My Blog
(5,330 Views)
