Directing file to location in application installer
I am building a LV installer and I want ensure that a particular file (.docx) ends up in a particular location on the hard drive so that the exe can be guaranteed to find it.  I'm not finding any clear instructions about how to do that.
Any suggestions out there?
Dave
(2,689 Views)
When creating the application builder, you can define destinations for the source files.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,671 Views)
First,  make sure the file is somewhere in your project.  Then in the build spec for the installer, you use the Source Files section to put the file where you want it.
(2,616 Views)
