Disable Combo Box Wrapping?
Is it possible to disable combo box wrapping?  I would like to right-justify text in a combo box and display the right-most characters if the text is larger than the size of the combo box.  Currently, if the text is larger than the box, it appears left-justified due to wrapping.
CLA, CTA
(3,064 Views)
Hi LVB,
I see what you are running into, but unfortunately word wrapping cannot be disabled in a combo boxSmiley Sad. You'll have to find some other way to set up your UI.  Of course, you can always submit a product suggestion for this option.
Brian A.
(3,035 Views)
